Question Rearview Mirror Fell Off!!!
I was driving my 75 Carrera yesterday and for no apparent reason, the rearview mirror came off. I did a search and a thread came up from 2001. Someone used superglue and epoxy with no success. There is also an adhesive pad from our host to glue the mirror back on. The picture shown is the same shape as my mirror pad (trapezoid).
http://www.pelicanparts.com/cgi-bin/smart/more_info.cgi?pn=901-731-133-20-M260&catalog_description=Mirror%20Adhesive%20Pad%2C%20% 39%31%34%20%31%2E%37%2F%31%2E%38%2F%32%2E%30%20%28 %31%39%37%30%2D%37%36%29%2C%20Each%20 Does anyone have experience in this product?
Please let me know if anyone has had this problem and what the best solution was. Thanks.
Greg
____________
75 US Carrera
03 Cab 2
69 Z11 Camaro Pace Car
Old 03-19-2009, 05:33 AM
daily driven 911
most parts stores sell a "Rearview Mirror glue" ive had pretty good luck with that....
Old 03-19-2009, 05:37 AM
Having tried several products... two seem to work very well. Permatex makes the other one, the glue is in a small white plastic vial, you break the tip of the nose and use exactly one drop of it. The kit is pretty impressive; it includes sandpaper, razor blade, and a cleaner/glue activator swab. Follow the instructions to the letter!
Another one was a similar product, but the glue was 2-component stuff in one double layer vial or tube. You crush the inner (glass) tube by squeezing the outer plastic tube. The two chemicals mix, and you then have limited time to apply the glue. Worked great. Found this at advance autoparts.
Both assume you are able to glue just a lightweight mirror mounting button on the glass, and that you are able to hold pressure on it for a minute before letting go.
I once had to glue a whole mirror assembly, a LOT more weight.. so I used a telescopic hood prop bar to make sure something was pressing the thing against the window glass for half an our. It worked too. My arms would have died in 2 minutes
Old 03-19-2009, 05:47 AM
muck-raker
kidrock's Avatar
+1. This is how it's done. You can get it at any local auto parts store.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 03-19-2009, 06:20 AM
I tried a couple of the parts store glues and none worked. I ended up with factory adhesive pad and it's worked flawlessly.
Old 03-19-2009, 09:37 AM
rgrimm's Avatar
Actually, one winter evening I started up the daily driver and watched as the rearview mirror fell off. I ended up going to a glass replacement/interior trim shop and a guy glued it back for me. We had a nice conversation and he must have appreciated my company...when I asked him how much, he just shook his head and sent me off...
Roger
1968 sand beige 911 Normale coupe #11830091
1984 metallic moss green with champagne interior 911 Carrera coupe
2012 silver with red interior Boxster
Old 03-19-2009, 01:44 PM
nameisbauer's Avatar
Send a message via AIM to nameisbauer
Originally Posted by dailyatx82sc View Post
most parts stores sell a "rearview mirror glue" ive had pretty good luck with that....
+1
Jim
911 Mint Green "RSC" #mintgrun
911 Gentlemen's Rallye 85 Carrera GP White
2012 C63 AMG Mars Red
Old 03-19-2009, 02:48 PM
