manifold boring question
How much can a 32mm carb manifold off a 2.0 be bored out? I have 38mm intake ports and will probably be running 44mm tb's. Will there be enough meat to bore them that far?
I tried searching but couldn't find what I needed. Thanks
'80 911SC R.O.W. Grand Prix White '88 325iX Diamantschwarz-Metallic |
![]() Here's the cyl. head side to ported to 36mm. Another 2mm (+1mm all the way around) is doable at the opening, but the gasket width becomes narrower at the 3 and 9 o'clock positions. ![]() I'd use a caliper to check the material thickness between the ends as you transition between the 44mm and 38mm openings. Sherwood |
Thanks Sherwood
I don't have the manifolds but I can get a set for $50 and am trying to find out if I should get them or wait for something better.
Let me know if you pass on that set.
thanks, Sherwood |
