how many sq' carpet pad needed?
1982 sc how many square feet of carpet foam should i purchase to install a carpet set?
many thanks for all the help and input from pelican's board and contributors. |
If you are buying a precut carpet set you don't need carpet foam. The carpet pieces will have the foam already attached in the areas it is needed.
| All times are GMT -8. The time now is 05:11 PM. |
