I did some searching on this and feel that my situation is unique.
I have about 4500 miles on a full rebuild that was completed in September of 2008. So far I have seen zero smoke - none on start up, none while accelerating, none while decelerating. This morning I cranked her up for work b/c the weather was nice. I got a nice puff of white smoke which really caught me off guard. I drove it 4 days ago for about 2 hours - long drive down some rural roads and some highway. When I cranked her up to leave work I got the same thing - nice puff of white smoke. In both cases it cleared up immediately. I feel like it almost had a sulfur smell but I could be wrong. Oil level is just above mid way so it is not overfilled. I am using almost zero oil. Car runs flawlessly and cool. I understand that this can happen from time to time. But, since it has never happened on this new engine and since it happened twice in one day I am a little concerned. I did all of the engine work except for the heads which was handled by EBS. I haven't had a leak down or compression test and understand that this will tell me if something is wrong. Hopefully I am just over reacting. Thanks, Craig
82 911SC Coupe Chiffon / Chocolate 9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD) Last edited by mca; 03-19-2009 at 05:39 PM.. |
How cold was it outside? What was the relative humidity? It could be as simple as condensation.
It was probably in the low 50s - parked in garage.
We are having some temp swings here - low 40s overnight and 70s during the day. But it was around 65 when I left work.
82 911SC Coupe Chiffon / Chocolate 9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD) |
hey craig, i noticed some smoke that day i was over there. i dont remember the color.
could it be seeping past the rings when sitting? would a comp check show something? the CD unit i gave you that had the cover on it, that one is good? dont get stranded again checking it, man i felt bad when tim told me. i just want to make sure you have a good reliable spare. i was looking at the 3.0 heads, did you knwo one of the valve springs was broken? did you ever hear anything? dont worry, not a problem, i was just curious if is something you can hear. i may be down next friday night.
Yes the CD with the cover is good. Let me know if you come into town and I will give you the bad one. Didn't know that one of the springs was broken. Which one was it? No, never heard anything and could nave been like that when I bought it.
just when you started it in the garage. no smoke behind you that i remember.
what cylinders does your car have, nikasil or alusil? you reused the cylinders right? i think it was an intake. if i can fix the other CD i make it a pelican loaner, perhaps even with a good coil.
