1967 911 (2.0L) timing?
Hi
I'm about to replace the points on my stock 1967 911 with an Pertronix Ignitor module.
Can somebody tell me how many degrees of ignition advance the 2.0L should have at full advance and at what rpm? ...maybe also what the timing approx. should be at idle?
I'm adjusting the ignition with a timing gun.
/Jacob
Old 03-21-2009, 04:56 AM
TDC/30 degrees BTDC @ 6000 RPM
Old 03-21-2009, 05:20 AM
So at idle the timing should be zero degrees (TDC)?
Old 03-21-2009, 09:20 AM
Tags
ignition , ignitor , pertronix , timing
