Tire Shop put lift in wrong spot - How can I fix the damage
Tire shop didn't lift the car at the specific jack points and pushed my rear seat floor pans in on both sides. How can I flatten these out again?
Author of "101 Projects"
Pics pls.
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
To others: heed this! Do not ever assume a tire shop knows how to lift a 911. Take your jackpad lift with you when you go, and supervise the procedure with a floorjack if you're not comfortable with pointing out lift spots. I think a floorjack is better suited at a tire shop. If they won't let you do this, go to another shop.
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
At the track = great day
If it isn't too bad, just use a rubber mallet. A few good hits with that and it'll be fine.
Lane 2011 Volkswagen Jetta SportWagen TDI Looking for another sports car.. |
GAFB
Depends. Are you an out of work lawyer?
Several BMWs |
Sultan of Sawzall
bfh
Gruppe B #319 2 '86 911 Carrera coupes (red & white) '66 Corsa convertible 140/4(red) '66 Monza coupe 110/PG(white) '95 993 cabriolet (wife's) |
Follow me
Man that sucks! I always tell them where to lift mine or the put it on a lift that you drive onto then the whole thing goes up. You should get them to fix it or reimburse you for the damage when you fix it. Good luck.
1982 911SC |
Hopefully they did not crush the oil cooler lines too in the process of guessing where to lift the car .... I second chkbookmechanic, nice large rubber malet will do the trick
Rich @ ROCS Last edited by 911Rich; 03-19-2009 at 08:01 PM.. |
Almost Banned Once
Use a block of sturdy wood and a hammer. I nice piece of pine is good. Don't use a dark hardwood.
Rubber mallet is good but I like using the block because you can't miss. |
sand/ease the edges of the wood to prevent creases. or cover in carpet. I've pounded out many-a-floor this way. rubber mallet is good, but a plastic faced deadblow is better.
1.367m later
non velox ad propitiare, verisimile non oblivisci If it's not The Original Automotive Innovations and Restoration, then it's just hot AIR. |
1980 911 SC
I always drop off the wheels and tires and pick them up later.
Life's a Beach |
To avoid the lifting fiascos, the impact wrenches they might use, and monkey wrench wheel rash, I do the same except I always stay and watch. My thinking is that they'll simply be more careful mounting/dismounting from the wheel if you're there imo and I've never been disappointed. I remember one time, the "tire tech" was having a heck of a time getting the last tire balanced, and after two attempts he finally asked the manager for advice. He came out, and with some effort got it to balance perfectly. I'd bet that it would have been "good enough" the first attempt if I hadn't been standing there
thats why i take my wheels off and got the the shop, or i am out there checking to see how they do it.
Canucks Fan
dtw, liked the lawyer line , that guy was off base ,Q: what do you call 200 lawyers at the bottom of the lake? A: a good start
Recreational User
I would never let anyone but a trusted Porsche mechanic put my car on a shop lift.
Good One S_Morrison. HAHA
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling. |
I'm so glad I have a great tire shop to work with. I hear all the horor stories about these kinds of things and have always been afraid of hacks out there that get paid minimum wage to change tires.
For all those that suggested beating with a rubber hammer- what about the cracked insulation material on the floor inside the car? Any time I've seen a 911 lifted under the floorboards, the material inside cracks and chips away exposing the metal underneath, and sacrificing some bit of sound deadening. Redstormcoach- please tell us that the shop fessed up to their stupidity and offered to make it right for you. If not, take the car to a reputable body shop that knows 911's and get an estimate for them to repair the shop's damage.
Ed '86 911 Coupe (endless 3.6 transplant finally done!) '14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one) '97 BMW 528i (the sensible car, bought new) '12 Vintage/Millenium 23' v-nose enclosed trailer |
Friend of Warren
Ha, ha, ha, ha, fuch you, ha, ha, ha, ha.
Kurt V No more Porsches, but a revolving number of motorcycles. |
GAFB
Several BMWs |
