911s get great gas milage
mike gilbert's Avatar
Drivers Door Dome Switch Wire Lost In Hole
I was removing the switch to clean the contacts and the wire slipped out of its crimp and fell in the area behind the door jam. I been fishing for it with a coat hanger with no luck and I cant see and access. Any help would be very much appreciated. Really would like to get it sorted because this switch also activates the factory alarm that I still use. Thanks
83 911SC Coupe
72 914-4
Old 10-09-2014, 01:11 PM
Classic's Avatar
Look under the dash, high into the wheel arch, and you should see where it enters the door post.
Pull it out a little and see if you can feed the wire so that you can feed it upwards towards the hole.
Other than that keep fishing.
Classic 1969 911T
Old 10-09-2014, 01:31 PM
douglas bray's Avatar
Boroscope with a hook. Been there. Got mine at Pep Boys.
I even used mine to suck sugar water out of an engine. Taped a small rubber tube to it and fed it down through the spark plug holes. Magic. Almost caused my insurance to total the poor thing. Did all the work myself. Still looking for the little prick that put his sugar/antifreeze concoction in the tank of my E350.
Old 10-09-2014, 04:12 PM
Heck, I’m only 5 not 71!
targa80's Avatar
I agree with Classic the wire can be retrieved via the opening in the foot well. When I was reinstalled the harness I ran a thin snake wire (or coat hanger) into the switch hole and fed it upwards until I could grab the snake end from the foot well opening. Used electrical tape to secure the wire to the snake and pulled it back thru the switch opening. I used this method on both sides and it saved time instead of trying to feed the wire back down to the hole and grab it from there.
Pat Henry
Targa80
1980SC Targa (Mocha Brown)
Old 10-09-2014, 07:01 PM
Dial 911
A horse with no name's Avatar
wire that works well
Hi, for what it is worth, I have for decades used the wire that steel workers use for tying 're-bar' together for many different uses. It does work well for pulling electrical wire through.
Cheers!
Cheers!
“Simplicity is the ultimate sophistication.”
Leonardo Da Vinci
Old 10-10-2014, 03:51 PM
Senior Member
Jdub's Avatar
A magnetic extension may help here. I almost always use a small binder clip to hold wires away from situations like this.
'78 Targa in Minerva Blue
Old 10-10-2014, 03:55 PM
