Harbor Freight jack
My US General aluminum jack from Harbor Freight needs help!!
When I try to raise the car, only the last 1/4 of the pump stroke results in lifting action. Does it need fluid? Does it need bled? If so, does anyone know how? Plese spare me the drivel of why I should not have bought a Harbor Freight jack in the first place...it has worked great for 4+ years!
2003 996 Carrera gone but not forgotten '88Carrera '96 993 '89 951 |
Make Bruins Great Again
After about 4 years of infrequent use, my HF AL jack did exactly as you described. I bought a bottle of Jack fluid at Sears and filled and bled the jack (as per the manual that came with it) and it works like new again. Check for leakage and if not, you have a cheap and easy fix.
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
Instructions anyone?
Does anyone have the instructions and can tell say how to bleed the HF jack?
Thanks !!!
I love the Chinese calling a product "US General."
Stephan Wilkinson '83 911SC Gold-Plated Porsche '04 replacement Boxster |
AutoBahned
makes perfect sense...
they export it to the US and it Generally crap |
I have a couple HF jacks. Same issues, same fix. No complaints here.
1979 911 SC Silver 2002 996 race car 2005 Ford Excursion |
Everyone says what crap HF jacks are. I've heard the same said about Craftsman and they are twice the cost. I will admit I had a bad (almost deadly) experience with a pair of HF jack stands and I will not trust my life (or my car) to them again but the jack has been great. Keep in mind that I don't use it daily.
bigsid
Por-sha911: can you elaborate on your hf jack stand failure? What size and model were they?
Thanks |
Thank you Driver8 !!!
![]() IIRC there is a bolt (more like a pin) that holds the lever that releases the extended part of the jack up. It just sheared off and the jack fell to the lowest position. When I returned it, the manager gave me a full refund and a new set of stands (which are still in the unopened box). I went across town and bought a set of Craftsman stands that are far more solid. BTW, has anyone seen the humor in "NO LIFT" posting a problem with his jack not lifting?
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera Last edited by Por_sha911; 03-22-2009 at 08:12 PM.. |
Soldier of Fortune
See the jacks available for sale on this site. Nonetheless, this subject has been beaten to death here. Do a search for "floor jacks". P.S. - "NO LIFT" registered on this site to ask a question about his jack, so the name fits. |
19 years and 17k posts...
You trust your life with this jack? I wouldn't... be careful!
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
i have an HF jack. i had another for 10years +, the seals went bad but i could not find new ones. i hated my new HF jack. when i would lower the car, the jack would literally drop it. there was no slow lowering f the car. i guess it needed to be broken in, it is much better now.
Maybe I don't use a jack the way you do. I LIFT the car and then put it on jack stands. I am not underneath when the car is being raised or lowered.
T77911S: I don't have any of those issues. Did you bleed the jack when you purchased it? Anyway, as was mentioned, this has been discussed before (hey, for once I didn't get accused of being rude for pointing that out ) and as they say: to each his own
RE: Harbor Freignt Jack...
Harbor Freight tools are only good for extremely limited or one time use. For a tool as important as a jack, Harbor Freight is not in my list of top 10 tool suppliers.
If it flows, it goes. If its smooth, it moves. Any questions? 96 993 C2 (Current) 87 911 Factory Turbo-Look Cab (Sold) 85 911 Factory Turbo-Look Targa (Gone) |
