-   -   Alternator problem (http://forums.pelicanparts.com/porsche-911-technical-forum/464310-alternator-problem.html)
tabasco 03-21-2009 03:47 PM
Alternator problem
I need some help to diagnose my alternator problem, on a '76 carrera 3.0.
My alternator light is dim at idle and gets brighter when the RPM increase.
I had 13.8V at the battery, so this tells me the alternator is charging.
I bought a new voltage regulator from our host, I thought it would be a good idea to replace the old one (probably mechanical). The old one is a white marchal.
With the new one in place, the light was even brighter, and I measured up to 17.0V at the battery ! So I put the old one back.
I've read many posts and I think I understand the charging diagram. The fact my light is on means there's an imbalance between B+ and D+.
With lots of volts at the battery, I suspect a weak D+ output.
What would cause this ? Bad diodes ?
Maybe I have 2 issues, a weak D+ and a lazy voltage regulator ?
What other tests should I do ?
I've never removed the alternator so I'm not sure it's the one that I expect (marchal) in there.
Where can I measure the D+ voltage ?
Thanks !
-Guillaume
Por_sha911 03-21-2009 05:42 PM
Are you sure you hooked up the wired correctly? Did you double check to make sure you had the right one?
