AutoBahned
Front Torsion Bar Screws
Can anybody post a pic of the new style adjusting screws for the front torsion bars?
These are the ones with the plastic collar on them. Thanks! |
Plastic collar? I have an 88, which should be close to the latest 911 that has front torsion bar adjusting screws, and there is no plastic collar on mine. Just an M10 (or is it M12?) bolt with an 11mm hex head and a rounded tip.
'88 Coupe Lagoon Green "D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen" "We must not allow a Mineshaft Gap!" |
AutoBahned
hmmm - there is an old post by Grady that says the plastic collar is there on the newer style to prevent the bolt from turning on hard bumps/corners when it is unloaded...
Not on my '88 either.
With 19mm torsion bars and reasonable ride height (that would be my setup), the rebound stop in the shock/strut will stop suspension travel before the torsion bar is unloaded. Of course, a lowered car with 23mm front bars may go the other way.
I marked mine with a dot of yellow paint, and they have never moved on their own.
sudo apt-get purge 930
The pair I bought last year just had some blue paste like stuff to prevent unthreading, sort of like nylock material but more pasty if that makes sense.
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
AutoBahned
that blue stuff is a type of thread locker -- pretty sure Grady meant something else... I re-installed the original ones -- if I have problems (unlikely) then I can always drill & safety wire them so they won't turn. |
Even if one wheel comes off the ground, the torsion bar may still be loaded. Pretty simple to check - after you adjust your front height, jack up one side until the wheel is off the ground, and see if the adjuster has slop in it or not.
