-   -   Odd front turn-signal wiring issue?? (http://forums.pelicanparts.com/porsche-911-technical-forum/464355-odd-front-turn-signal-wiring-issue.html)
DCOP 03-21-2009 07:07 PM
When the parking lights (US version) are on all seems normal (the parking light filament of the 1157 bulbs is lit). When you select the left or right turn-signal the front parking light filament blinks instead of the actual turn indicator filament? Seems odd but perhaps difficult to trace. The turn-signal indicator switch is fairly new. Any suggestions on what to look for? Thanks Darryl
kodioneill 03-23-2009 07:29 AM
has this problem always existed? did this begin after the signal switch was replaced?
DCOP 03-23-2009 05:57 PM
I never really noticed it until I took the lights apart to wire in a city light wire for my new H-4s. I was very careful to run the city lights off the parking/side marker light wire. My turn signal flasher lights on the dash have always blinked together and what seemed to be dull front blinkers, even before I replaced the switch. I had problems with the high-beam part of the turn signal switch, hence the reason to replace it. New switch did not solve the dash indicator lights blinking together?
