3.0 -> 3.2 question
To make a long story short, I bought my 911 -79 with no engine.
Now I have found a 3,2 from "G-modell" I still havent got any engine number so I dont know what year its from... However I do know that came with the 915, so far so good. My question will this engine fit my car cablewise, regarding ignition and so forth? /mike |
I have done this conversion the other way. You are going to have to do a custom wiring installation. The SC is designed for CD ignition and the later motor for computer control. You will also have to change the fuel pump and probably some fuel fittings or lines.
Bryan |
Make sure the 3.2 comes complete with a harness, brain, altitude sensor, coil, and the fuel pump relay.
You dont need the 3.0 accumulator or the CD box from the SC. Lay out the harness down the drivers side and attach the brain, relay, and alt sensor under the seat to the floor. Drill a hole in the rear under the seat, below the torque tube to pass the wires through to engine compartment. I m not going to explain everything here just highlights but be sure to tap the coil wire into the safety lights because it needs power in the start position and the brain runs the fuel pump so you run the pump drive in the top of the fuse removing the chassis wire for the pump. Bruce |
| All times are GMT -8. The time now is 12:16 PM. |
