Jupiter 911
bklyn's Avatar
Speedo advice
Gents, the speedo works but only after I tap it with my finger, the odometer has not worked for over a year. Can you advise if the speedo on my 87 Targa is cable or electrical, I have not yet removed it, thanks.
Lenny-1987 3.2 Targa Guards Red/SW Chip
Fabspeed Exhaust/Cat bypass
MSDS Inc. intake/Clewetts
Euro pistons and cylinders.
2002 Boxster Artic Silver/Wifes ride.
Old 03-23-2009, 04:10 PM
IROC's Avatar
Your speedo is electric. Mechanical speedos ended during the 1976 model year.
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 03-23-2009, 04:15 PM
t951's Avatar
If you're a man you should never wear a speedo.
Hope that helps.
tk
08 911 C2S - Sold
13 Audi A4
14 Jeep SRT 500HP
Old 03-23-2009, 04:27 PM
Jupiter 911
bklyn's Avatar
I know there are several places to send the speedo out to be reconditioned but should I try to repair it myself?
There is an electrical sender/switch accessible on the outside of the tranny. It an be easily removed and tested before spending on a speedo rebuild.
Bill M
88 Carrera
86 944 SP1
06 Cayman SPC
Old 03-23-2009, 04:28 PM
Jupiter 911
bklyn's Avatar
Bill, how should I check the switch?
Old 03-23-2009, 04:32 PM
Lenny, there is a plug in the shift tunnel you disconnect then remove the bolt that holds the switch itself into the drivers side of the tranny. It's a simple mechanical switch that you can trigger with by holding a magnet to it and checking the circuit for continuity at the plug with your multimeter as you move the magnet on/off. Two man job if you leave the switch on the car while you test it.
Bill M
88 Carrera
86 944 SP1
06 Cayman SPC
Old 03-23-2009, 04:46 PM
Jupiter 911
bklyn's Avatar
Thanks Bill, I will give it a shot tomorrow.
Old 03-23-2009, 05:01 PM
