ac in a 78 911sc euro
I have a condenser behind my rear left wheel is it normal, and how do you test if it is working properly?
thanks
Arnaud
Old 05-21-2009, 05:20 PM
Send a message via AIM to fintstone
It is aftermarket.
What is your vent temp?
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 05-21-2009, 06:34 PM
do not now the temp.
it does not turn
but so doesn t the compressor clutch: no voltage
Old 05-21-2009, 07:03 PM
What does not turn? A fan on the condensor?
Old 05-21-2009, 07:26 PM
Detached Member
Hugh R's Avatar
Probably an after market A/C system. I have the same thing. It has a fan. If compressor clutch isn't engaging, you need to solve that first. I doubt your year car had a high/low pressure switch. Do you have refrigerant? Push on the A/C charging valve, it's like a tire valve and see if it hisses. That's the first thing to do. If no hiss, you need to pull a vacuum and recharge with freon or more.
Hugh
Old 05-21-2009, 07:33 PM
