Rear torsion bar position question
Have read deeply here about torsion bar settings but am still confused about one point. If
I like my ride height where it is, and I switch from a 23mm torsion bar to a 27mm bar, do I want to get the trailing arm angle as it was before the swap or somewhere different? Car is a 74. Thanks,
jhtaylor santa barbara 74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's. 73 Targa (gone but not forgotten) |
Use this calculator.
Thanks Milt. I infer from the calculator that the angle is going to be different. Actually, reading his technical explanation makes it all pretty clear. Thanks again,
jhtaylor santa barbara 74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's. 73 Targa (gone but not forgotten) Last edited by moneymanager; 03-28-2009 at 06:10 PM.. |
What Milt says.......in other words it WILL be different
Dan '86 911 Targa Driver '76 911 Targa 3.0 Track Toy 46mm PMOs, 10.5/1 J&E,Web Cams, Wide Body fenders, 23mm and 30mm Hollow T-Bars, 930 Sway bars, Bilstein Sport Shocks, Plastic Bushings (too damn squeeky) |
Yep, setting the ride height by using the droop angle makes it different. In the end, the spring plate will be at the same angle with the car on the ground. Confusing.
So just to be completely clear, the droop angle I seek will be different with the new bar when the suspension is off the ground, but it will be the same as it was earlier when the car is on the ground bearing weight (and the body is in the same position relative to the wheel as it was when I started)?
Right.
As long as ride height stays the same, droop angle will be less as a bigger bar will twist less. (in my experience with the bars on a 944)
Jess 1980 911SC Euro 1993 Audi CSQ |
Makes sense. Many thanks all.
