A level floor is a flat floor. You need is a flat floor.
Check tire air pressures. Might be good to run the pressure up high to take a bit of the tires spring rate out of it. Just some guesses. Love the bottle jack with a pressure gage plumbed in. |
this is really splitting hairs.
If I get to within 120 lbs of where I want to be, it's good, If I get to within 80 pounds, its perfect. The best shops consider the car being 'corner balanced' if it gets within 50-100 pounds of target. These rudimentary tools should only be used for proximates. Or not. I mean, if you are set up like Penske, I agree with all the above: http://forums.pelicanparts.com/uploa...1238432673.jpg http://forums.pelicanparts.com/uploa...1238432689.jpg |
| All times are GMT -8. The time now is 09:26 PM. |
