-   -   911 SC trouble with the turn signal (http://forums.pelicanparts.com/porsche-911-technical-forum/466060-911-sc-trouble-turn-signal.html)
rjrandalls 03-29-2009 09:30 PM
Was having intermittent problems with the turn signal. Irregular blinking, sometimes not at all. Now completely died (both sides).
Replaced the turn signal switch on the steering column. Very painful reattaching those wires!
Still doesn't work. :(
Could this be the relay? Where is that relay, anyway? Any help would be appreciated.
cantdrv55 03-29-2009 11:28 PM
It might be the flasher relay which is located in the dashboard behind the fuel and oil gauges. It wouldn't hurt to buy one and swap it out. No worries if that doesn't fix it because I guarantee that it will go bad eventually.
rjrandalls 03-31-2009 05:28 PM
Thanks for the advice. I'll check it out!
