brake after bleeding
hi there
how should the brake pedal feel after bleeding the brakes
thanks
Arnaud
Old 03-31-2009, 11:34 PM
DanielDudley's Avatar
Like a rock.
Old 04-01-2009, 02:04 AM
Almost Banned Once
sc_rufctr's Avatar
X2... It should feel solid and reassuring...
- Peter
Old 04-01-2009, 03:05 AM
cycling has-been
bkreigsr's Avatar
if you bled the system to the point that the reservoir itself emptied, you've got air in the system, and your pedal probably feels like warm oatmeal. (speaking from experience)
Bill K
Old 04-01-2009, 05:37 AM
Somatic Negative Optimist
Gunter's Avatar
Question
Very solid.
Just a bleed, or did you do something else?
How did you do it? Pressure bleeder or Pedal-pump?
And, by all means, don't tell us what year/type your Porsche is.
Cheers.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 04-01-2009, 08:50 AM
it is a 78 911 sc
and I did with a vaccum bleeder
twice on each caliper
the only thing is that i have the feeling that the bleeder is also pulling some air coming from the loosened bleeding screw(from outside the caliper)
the manual: 101 project for your porsche says you have to make it several time so.
Old 04-01-2009, 11:44 AM
cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
Drive it for a while. Do many hard stops. It will firm up. I have the same issue using the vaccume bleeder. don't know why.
Chris
73 911 E
Old 04-01-2009, 02:09 PM
Southern Class & Sass
Dixie's Avatar
Air getting past the bleeders is not an issue. Being able to discern if the air is from the bleed screw threads, or inside the caliper, is the trick.
Try this. Put some grease around the base of the bleed screws (di-electric grease works fine). That will block air from getting past the threads. Now if you see bubbles, they're from inside the caliper.
Also, the "like a rock" analogy can be misleading. The pedal should feel extremely firm. But it will feel even firmer if you release it, and press it down again.
Dixie
Bradenton, FL
2013 Camaro ZL1
Old 04-01-2009, 02:26 PM
