77 911 vacuum ?
1977 911 2.7 what is the part on the left side of the engine the vacuum lines are going to ? It has a electrical connector on it and is there anyway too test this? I am wondering cause i am loosing vacuum to the advance on the distributor thanks for any help
Post some pictures.......
It would be helpful if you attach some pictures regarding your inquiry. My guess would be TTV (thermotime valve). HTH. Tony |
when my engine was almost completely CIS stock I plugged the distributor vacuum retard hose permanently. I then set idle advance to 5 deg BTDC and checked total to read 35deg BTDC. It ran great that way for years.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
the 77 has retard not advance.
