Cattler's Avatar
Porsche Crest Intensive washer reservoir
I've read most of the threads on this and I know I should be looking for a very small reservoir near the fuse block. I can't find it, but I have the switch for intensive wash on my dash.
Does anyone have a picture of this reservoir in its secret location?
Did Porsche install the switch but not the system in all cars? I thought it was standard equipment and not an option...
Thanks,
1987 911 Carrera Cabriolet (sold)
2009 Prius (daily driver--keeps me sane)
2011 Mercedes GLK350 (wife's car)
2002 Volkswagen Beetle Turbo S (son's car--keeps wife sane)
Old 04-01-2009, 06:11 PM
N-Gruppe doesn't exist
teenerted1's Avatar
Location: *%@#ing GPS, where am I? Oh wait I see the Space Needle.
Send a message via AIM to teenerted1
search is your friend
http://www.pelicanparts.com/cgi-bin/smart/more_info.cgi?pn=996-528-701-00-M100&catalog_description=Washer%20Fluid%20Reservoir%20W indshield%20Washer%20Fluid%20Headlight%20Washer%20 Fluid%20NOTE%3A%20Only%20for%20cars%20with%20M%32% 38%38%20Headlight%20Washer%20%2C%20Boxster%2FBoxst er%20S%20%28%31%39%39%37%2D%30%34%29%2C%20Each
Ted
'70 911T 3.0L "SKIPPY" R-Gruppe #477
'73 914 2.0L SOLD bye bye "lil SMOKEY"
"Silence is Golden, but duct tape is SILVER.”
other flat fours:'77 VWBus 2.0L & 2002 ImprezaTS 2.5L
Old 04-01-2009, 06:17 PM
Cattler's Avatar
Probably should have been clearer...I have an 87. That part is for newer cars with headlight washers. I'm talking about the intensive washing system that dispenses a special fluid--I suppose for especially dirty windshields.
Old 04-01-2009, 06:21 PM
Band.
Your '87 has headlight washers, does it not? I know on an SC, anyway, the fluid for the windhield and headlight washers comes from the same place. Windshield pump is seperate from headlight pump, though.
I've never heard of the 'special smaller reservoir with special fluid", though. There's a reservoir under my hood that says "DOT-3" on it, that fluid will clean damn near anything.
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 04-01-2009, 06:24 PM
Canucks Fan
Hi
I have the same system on my 87 930 the resivior is located by the LF shock tower kinda beside the brake MC resivior, its a high intensive cleaner to spray windows and headlights on a metred amount , you hit the switch and it will pump for 5 seconds or so and then shut off, bought some of the special solution from P and it was super expensive
Old 04-01-2009, 08:25 PM
GothingNC's Avatar
John D.
82 911 SC Targa-Rosewood
2012 Golf TDI
Old 04-02-2009, 04:36 AM
Almost Banned Once
sc_rufctr's Avatar
Does it work? I mean does it do a good job of cleaning the windows and headlights?
- Peter
Old 04-02-2009, 04:43 AM
Alii&Maui
Jesset100's Avatar
Whats the part number on the reservoir?
1982 SC Coupe
SCWDP#0087
KCSSL#0082
Old 04-02-2009, 04:48 AM
911 628 027 00 is the part number for the reservoir. I think it has been discontinued so, if you want one, you'll have to find a used one. The intensve washer system was originally an option. I don't recall if it was ever made standard equipment.
The intent was this; for prolonged travel in rainy weather to be able to better clear the windshield. Porsche figured that a greasy film developed on a windshield in such conditions and the normal system wasn't able to properly clean it off. They used a special chemical that they called a silicone remover in the tank and it was sprayed in short increments (a second, or less) at a relatively high pressure. You were still supposed to do the main cleaning job with the standard system, using the special one only occasionally when the windshield seemed streaked.
Frankly, I have the system on several cars and never found it very useful. It solved a problem I never really had. Nowdays, I never drive the old cars in the rain anyway, so it's just one more thing that can leak and screw up what's in the trunk.
JR
Old 04-02-2009, 05:42 AM
Is this for real or April fools?
Old 04-02-2009, 05:45 AM
Which part?
JR
Old 04-02-2009, 06:09 AM
Slumlord
Porsche_monkey's Avatar
What do you guys use for the cleaner?
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
What Porsche sold for the system. "Porsche Special Silicone Remover." The part number is 928.628.931.00.
JR
Old 04-02-2009, 06:19 AM
Slumlord
What if you are too cheap to buy Porsche stuff? Without naming names.
84 Cab - sold!
Old 04-02-2009, 06:22 AM
Almost Banned Once
sc_rufctr's Avatar
Mild dish washing liquid should work but it would foam up on the screen edges.
AMWAY used to make a soap called LSD (I think). It was a detergent but didn't make bubbles. Just an Idea.
- Peter
Old 04-02-2009, 06:26 AM
Slumlord
What if you hate Amway?
84 Cab - sold!
Old 04-02-2009, 06:28 AM
Almost Banned Once
sc_rufctr's Avatar
I'm not sure.
Maybe there is something like carpet shampoo that does foam that you could use.
You can rent carpet shampoo/cleaners at my local supermarket and there you can buy detergent and other chemicals off the shelf. They have an anti suds chemical you put in the catch bucket for the muck you get out of your carpet.
I would be hesitant to try anything like that because of the potential to damage the paint on your car.
I'm guessing this would be useful for you living in Canada.
- Peter
Old 04-02-2009, 06:35 AM
Slumlord
I was sort of kidding, if Amway makes something I will try it. I drive my car year round, so yea, it would be nice to have something good on there.
84 Cab - sold!
Old 04-02-2009, 06:40 AM
Wavey's Avatar
There are links within this thread with the part numbers and some suggested sources:
Need any info for high-intensity washer conversion
Deceased: Black '88 Carrera Coupe, Steve Wong and Russell Berry chips, Dansk premuffler, custom MK GT3-style muffler, Magnecores. Al Reed 7 & 8 X 16 Fuchs. Full Elephant Racing suspension, 21/28 T-bars, Turbo tierods, bump steer kit, Bilstein Sports, BK strut bar. Ruf bumpers, 935 mirrors, Carrera 3.0 tail, DasSport bar.
'11 BMW 328iX, '18 Nissan Frontier 4X4, '92 Acura NSX.
Old 04-02-2009, 06:42 AM
Recreational User
porschenut's Avatar
If anyone wants to buy the washer reservoir and 2-year-old working pump from my '86 Carrera, PM me.
