Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 911 Technical Forum
probably should replace the o-ring on the adapter while it's accessable. you know how the black noeprene original gets rock hard and leaks.
jwworkshop@aol.com 206 789 6800
7613 greenwood ave n seattle wa 98103
Old 04-03-2009, 05:55 PM
  Pelican Parts Technical Article Directory    Reply With Quote #21 (permalink)
Author of "101 Projects"
Wayne 962's Avatar
The pictures must make it look really good - there's nothing "accessible" in there at all. You can barely stick your hand in there, let alone get too many tools in there. Agreed, that the o-ring might start leaking sometime in the future, but I'm inclined to leave it alone. Only took me about 30 minutes to get to this point.
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of:
101 Projects for Your BMW 3-Series 101 Projects for Your Porsche 911 How to Rebuild & Modify Porsche 911 Engines 101 Projects for Your Porsche Boxster & Cayman 101 Projects for Your Porsche 996 / 997
Coming Soon:
SPEED READ: Porsche 911 (October 2018)
Old 04-03-2009, 08:29 PM
  Pelican Parts Technical Article Directory    Reply With Quote #22 (permalink)
TibetanT's Avatar
Good job!
By the looks of it, the fuel filter looks as if it is in a very tight spot as well. Is that true or easy to get to with a 17mm and 19mm open end? Just wondering how difficult a normal maintenance is.
Ed Paquette
1983 911SC
1987 944 Manual (Donated to the Nat. Kidney Foundation)
1987 944 Automatic (Recently sold to another Pelican)
Old 04-03-2009, 10:40 PM
  Pelican Parts Technical Article Directory    Reply With Quote #23 (permalink)
Wayne 962's Avatar
Okay, so Part II continues. Here's the view of the engine bay as we left off yesterday:
Here's some random vacuum canister device that I needed to clean up a bit prior to putting it back in the car. I'm not 100% sure what this does, but it looks important.
Here's the old and the new. Unfortunately, the new one has a bit larger lip along the bottom, which did cause a problem on installation. I had to wedge it in there a bit, as I could not turn it easily by hand when I was installing it.
Got a new copper washer/gasket to put in place so the sender won't leak.
Since I had problems seeing if the sender was mounted properly, I used a small inspection mirror. Fuzzy photo, but you get the picture.
There's the sender installed. I used the crowfoot wrench with a combination of some soft maneuvering with some vice-grips covered in duct tape. You don't want to use the "grip of death" when installing new parts, or you might damage them.
Carefully install the new electrical connector back on top.
Here's that mystery vacuum canister valve going back in.
Tighten up all of the hose clamps (this car has like 30 vacuum hoses in the engine compartment)
Looking good. We'll now carefully start up the engine to test to see if the sender is working properly, prior to reinstalling the pain-in-the-butt-to-install air cleaner.
Coming Soon:
Old 04-05-2009, 08:29 AM
  Pelican Parts Technical Article Directory    Reply With Quote #24 (permalink)
Wayne 962's Avatar
Here's the reading on the dashboard gauge. Seems high at first, but this is what it typically looks like when the engine is cold and the oil pressure is high.
All buttoned back up! The big hose clamps for the air intake tubes are at work, I will have to attach those later on.
-Wayne
Coming Soon:
Old 04-05-2009, 08:30 AM
  Pelican Parts Technical Article Directory    Reply With Quote #25 (permalink)
Never left, but not right
Zeke's Avatar
So, does this mean you will make Fontana today? Didn't see you yesterday. You need to do some lunch time laps in the 959!
Old 04-05-2009, 08:57 AM
  Pelican Parts Technical Article Directory    Reply With Quote #26 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
red67's Avatar
cool 8) the engine bay is amazing looking on a 959.
it's a real privelege to see one up close in detail and being worked on. thank you!
wayne i just watched a little video on the 959 on youtube and in it, there's a closeup shot behind the drivers side door on the body, and theres a little flap (like a '72 911) what's that for? - is it where you put gas in on a 959 or oil or "something else"? and why is that flap in that particular place?
Paul
'76 911S - cockney brown
'69 911T coupe - tangerine
'73 911T targa - light ivory
'67 911 coupe - polo red
Old 04-05-2009, 09:19 AM
  Pelican Parts Technical Article Directory    Reply With Quote #27 (permalink)
Max Sluiter
Flieger's Avatar
I saw his car there at 1:30 Saturday.
911S
1971 chassis, 2.7RS spec MFI engine, suspension mods, lightened
http://www.flickr.com/photos/max_911_fahrer/
Old 04-05-2009, 11:32 AM
  Pelican Parts Technical Article Directory    Reply With Quote #28 (permalink)
Wayne 962's Avatar
I was there yesterday, car was parked on the vendor row! Pics are going up soon...
-Wayne
Coming Soon:
Old 04-05-2009, 01:15 PM
  Pelican Parts Technical Article Directory    Reply With Quote #29 (permalink)
Wayne 962's Avatar
It's "something else". It's the filler for the hydraulic fluid for the suspension / shock / hydraulic lifter system. I'm not really sure why it's on the outside like that, but when I fix that system in a few weeks, I'll take some photos of it...
-Wayne
Coming Soon:
Old 04-05-2009, 01:16 PM
  Pelican Parts Technical Article Directory    Reply With Quote #30 (permalink)
Zeke's Avatar
-Wayne
I left at 11AM. Guess you weren't there yet. We had a car to go look at to buy.
Old 04-05-2009, 02:16 PM
  Pelican Parts Technical Article Directory    Reply With Quote #31 (permalink)
Pete000's Avatar
So,,,, problem solved????
Work to Live, don't live to work...
Old 04-06-2009, 07:47 PM
  Pelican Parts Technical Article Directory    Reply With Quote #32 (permalink)
Metal Guru
911nut's Avatar
Wayne, congratulations on solving the problem. The feeling is not unlike winning the lottery.
What's the plan for the suspension?
Paul B.
'91 964 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, - 210 lb
Old 04-10-2009, 05:32 AM
  Pelican Parts Technical Article Directory    Reply With Quote #34 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
