Garage Construction in Northern NJ
Has anyone had any recent experience with either a pre-fab steel or modular garage installation in NJ? Bergen County to be specific. I'm looking for non traditional alternatives to expanding my one car concrete block garage. Thanks.
(the shotguns)
the common solution to cheap space here is pole barn construction. lots of space for not too much money.
you can even use regular vinyl siding on them if you like.
***************************************** Well i had #6 adjusted perfectly but then just before i tightened it a butterfly in Zimbabwe farted and now i have to start all over again! I believe we all make mistakes but I will not validate your poor choices and/or perversions and subsidize the results your actions. |
Platinum Member
Non traditional? How about raise the roof, if the ceiling isn't high enough, and add a 4 post storage lift?
Probably less expensive than adding on. Or I have ordered sheds from: http://www.mysheds.net/storage.asp Very good service, and they have sheds with garage doors, sized up to a 2 car garage. http://www.mysheds.net/garages.asp |
Thought about a storage lift, but I've heard more than one first hand account of those things collapsing...
Steve at Ultimate Garage would be good to speak with for ideas, although very high end. He's in Emerson.
http://www.ultimategarage.com/services.html
1980SC 2001 BMW 325xiT 1986 Jeep CJ7 |
Platinum Member
I'm believe accidents happen because people lower it without making sure all 4 safety latches are released, or don't maintain/adjust releases. If 1 stays latched, it will hang-up. |
I've spoken to a few guys that had the cables snap; not sure what this was due to, whether a material flaw or an operational error or malfunction. In any event, it is an option for a tall two-car garage, but my first choice would be three stalls abreast.
