-   -   compression vs valve adjustment (http://forums.pelicanparts.com/porsche-911-technical-forum/467084-compression-vs-valve-adjustment.html)
patrick300 04-04-2009 01:14 PM
when i first recieved this 1977 911 2.7 , the first thing i did was a compression test, well all the cylinders were between 150 and 120 number 3 was the highest, well the car wasnt running to good so i then did a valve adjustment and it still was running bad , well me and a friend just did another compression test and now number 3 has 60 pounds , could the valve adjustment cause me to lose that much compression?
vreference 04-04-2009 05:50 PM
If it was done incorrectly it could. Valves that are set without enough clearance will be damaged.
