Door window glass interchange
I have a 72 911 coupe and I changed the driver door window. Now it fits very snugly to the point it barely goes up and down the channel.
Are all coupe window interchangeable? I see that by PET the part number for 64-67 Left windows are: 901 542 101 20 - clear 901 542 101 30 - green tint Then from 68 to 84 they part number is: 901 542 101 25 - clear 901 542 101 35 - green tint Does someone know and can confirm the difference between the 64-67 couple door glass and the 68-84 glass. |
I found a window glass from a 70 911 coupe. It is slightly different -- narrower in the middle -- thank the one I had. The 64-67 glass binds in the channel whereas the 70 doesn't. They look very close - even the sekurit part number is the same - but the later one has a DOT number. Live and learn!
