1QuickS's Avatar
Weber jetting needed
I'm building a set of 42mm IDAs for a 3.2 with early 930 cams. The car will be used for DE events but is not a dedicated track car. I'm guessing that peak HP will occur at 6000 RPM so a 36mm venturi size would probably be best. Since the engine is a lower RPM engine I'm guessing F26 emulsion tubes would be better as opposed to F3's. Any real experience in jetting this engine would be appreciated.
Cheers,
Paul
Paul Abbott
Weber service specialist
www.PerformanceOriented.com
Old 04-06-2009, 07:56 AM
