Rrrockhound's Avatar
shop tachometer?
What are people using for tachs in the garage? I have the following meter below:
http://www.actron.com/product_detail.php?pid=16155
Some kind of electrical interference from the ignition system makes the digital display fluctuate so much it's totally useless. On my other cars, I can usually route the red and black leads to avoid the interference, but it doesn't help on the 911. I haven't been able to check the timing because of this. Would an analog tach work better?
1980 911 SC
2002 996 Cabrio
2000 Silverado
2011 Golf
Old 04-06-2009, 06:41 PM
Navin Johnson
TimT's Avatar
I just use the tach in the center of the dash.... its visible through the rear window..
Though performing timing exercise its nice to have a helper who will hold the car at 6000rpm while you check the timing marks..
I've checked timing solo peeking through the window...better to have a helper
'69 911 GT-5
'75 914 GT-3
and others
Old 04-06-2009, 06:49 PM
Yeah, I guess that's one advantage to a rear-engine car...
The only thing is, the tach on my 914 isn't super accurate, so I assume my 911 is no better.
1980 911 SC
2002 996 Cabrio
2000 Silverado
2011 Golf
Old 04-06-2009, 06:57 PM
Navin Johnson
TimT's Avatar
I use the same method for my 914..peek through the window... check the tach...better yet take the roof off
If your interested I have an extra tach (6 cyl) you could have for shipping costs... maybe wire it up with some alligator clips..
fwiw I have never been able to get a decent rpm reading, even on a high buck Fluke multi meter
'69 911 GT-5
'75 914 GT-3
and others
Old 04-06-2009, 07:03 PM
