Am I the first idiot to do this?
After a total engine rebuild, transmission rebuild, complete rotisserie body rebuild I was ready on Saturday to turn the key. Rebuilt suspension and brakes were on, wheels on the ground and engine and transmission were installed. Filled it up with fluids and after taking care of a couple little leaks it was time to fire it up. Nothing happened when I turned the key. Right...a couple fuses need to be in. Put in the fuses and turned the key, saw the oil pressure rise but no firing. I spent the entire day Saturday checking the ignition, then most of Sunday checking the fuel system then late Sunday afternoon I finally got it to sputter when I put the accelerator to the floor. But, it backfired so hard that it blew the pop-off valve right out of the airbox. I'm glad I had installed that valve, or I would have had an exploded airbox. That backfire made me re-check the ignition. I finally checked the firing order by reviewing Waynes book I used to rebuild the engine. Yes, I had them wired exactly like it shows in the picture....but then I read the fine print in the caption below the picture that said:
"Swap plugs 6 and 5 along, with plugs 3 and 2 for the SC and Turbo configuration"
It was one of those moments where you're so happy you finally figured out the problem, you're not angry with yourself for screwing it up initially. I switched the plug wires on the distributor and she fired up smooth on the first turn of the key. It was late Sunday night and not the appropriate time to do the 20min high-rev break-in (neighbors would not have appreciated it), so I shut it down after a minute.
Am I the only idiot that's done this?
Geoff
'82 911SC (Complete rebuild)
Click here to go to the project website that chronicles the rebuild process
Old 04-06-2009, 03:52 PM
moneymanager's Avatar
Apparently. But I've lots dumber things than that!
jhtaylor
santa barbara
74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's.
73 Targa (gone but not forgotten)
Old 04-06-2009, 04:18 PM
Friend of Warren
I can top that. I forgot to reinstall the ring gear when I did my rebuild. Didn't discover it until I tried to start the engine and the starter just spun!
Kurt V
Old 04-06-2009, 04:46 PM
Talewinds's Avatar
Ehh, I did that 2 weeks ago to my wife's old Altima, but I was hardly paying attention whilst doing the work because the car's hardly worth anything.
88' Carrera, Black/Black/Black, "Murdered Out" OEM.
06' BMW 'M' Roadster (Wife's car and WAY faster than mine)
Old 04-06-2009, 04:50 PM
Almost Banned Once
sc_rufctr's Avatar
That's a classic... (I've done this as well...lol)
- Peter
Old 04-06-2009, 04:53 PM
It took me forever to get the wiring right on my new 12-plug dual-ignition distributor when I rebuilt the gold-plated Porsche, and I think I probably even had the engine running backward at one point. Don't feel bad.
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Non Compos Mentis
I'm sure glad I've never done anything stupid.
Old 04-06-2009, 05:02 PM
Slumlord
Porsche_monkey's Avatar
Originally Posted by squidmarks View Post
Am I the only idiot that's done this?Geoff
No. Just the first one to confess in public.
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 04-06-2009, 05:44 PM
Almost Banned Once
sc_rufctr's Avatar
Really?... haha
- Peter
Old 04-06-2009, 05:45 PM
Back in the early seventies, I built a very highly modified 2.5L motor. I aquired a Vertex racing magneto from a friend, and thought it would be a cool addition. After building this pristine motor from the ground up and installing, I was ready to fire it up. It would not start, just back fired and sputtered. Turns out when I installed the Vertex with the plug wires I had fabricated, I hooked them up, attaching No1 from the Vertex to No1 cylinder, No2 from the magneto to cylinderNo2, and so on!! DUH!!! After getting them rehooked up in the correct firing order, I felt like anything but a mechanic, more like a f#@king idiot!
But when all was correct, the car was a rocket.
Grant
Old 04-06-2009, 05:50 PM
Nine9six's Avatar
Ouch! That had to hurt
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 04-06-2009, 06:24 PM
I drilled a hole in my kegerator for an extra keg and managed to hit on of the coolant lines. wifey was pissed
Carl F
2000 Ruby Red Dodge Stratus with high performance racing stripe SE edition WTF? (sadly gone, but not forgotten)
1997 HOnda Accord "Shaggin Wagon"
1987 All black Targa
1998 Lemond Zurich/Dura Ace
2005 Jamis Dakar Sport
2006 Lemond Reno
2 DOgs , 2 Cats, Shi@ton of fleas
1 Cool as Hell Wife that tolerates my stupidity
Old 04-06-2009, 06:41 PM
304065's Avatar
One of these days I'm going to get a tattoo that says 162534
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 04-06-2009, 07:22 PM
Kurt - sorry mate, but that is absolutely PRICELESS!!!
One of the very rare times that I have literally "laughed out loud" at something that one of my fellow 'drongo's' has done in a moment of madness (trust me, I've had many a few myself!!).
It's lovely to see that people on this wonderful forum are humble enough to admit such mistakes to all and sundry, and you all have my utmost respect for doing so
regards,
Old 04-06-2009, 11:04 PM
Nope, I did it. The previous owner of my '76, which still had the 2.7, decided that SC engine decals would look lovely in the engine compartment. I followed these decals when replacing the cap, rotor, and ignition wires. Same result as you, including the dislodged popoff. Took me a few days to retrace my error. Needless to say, the SC decal with the dizzy rotation and order was promptly removed.
Old 04-07-2009, 08:44 AM
sudo apt-get purge 930
equality72521's Avatar
Mine is 162435, a sequence I will never forget in my life. Ironically, it's the numbering sequence for connecting a three phase motor winding. After spending 15 years winding motors you don't forget it. Now, years after my motor winding days it is still coming in handy.
--clutch-monkey
Old 04-07-2009, 09:29 AM
1980 911 SC
Been there, done that, following the Bently's manual. It didn't say anything about SC's dizzy turning the opposite direction.
Life's a Beach
Old 04-07-2009, 10:17 AM
CBRacerX's Avatar
Done that one better by combining it with improper installation of the distributor. It ran, barely...
Chris
https://dergarage.com
‘07 GT3, '80 SC Weissach (For SALE), '01 986S, '11 958S, '18 Stelvio, '18 Dursoduro 900
Old 04-07-2009, 10:42 AM
I did the same thing on my 78 3.0. I did just what the book said, almost. It is one of the best feelings when that motor starts for the first time after the long build process.
Rich
1976 911/S/SC/BASTARD
Mid9 Member #12
Old 04-07-2009, 12:01 PM
