Czar of C.R.A.P.
Seat foam discoloration
OK took the covers off the totally toasted sport seats I recently aquired and under the cover the foam is a real dark green color. I first assumed it was mold. Have used oxy-clean, fungicide, bathroom cleaner everything I can think off but it doesn't even touch it. I put the entire foam section in a 5 gal bucket and soaked it then pressed out the excess water, nothing. Water was not even dirty. So now my question is would it possilby be dye bleed from the leather seats getting wet. I know that black dye is not really black. This is a really dark green. Foam otherwise is in pretty good shape.
66 912 Coupe 84 Carrera Cab Hardtop HC3.4 Hyper Carrera 2005 Dodge Magnum 5.7 HEMI Cabriolet Racing And Performance C.R.A.P. Gruppe #1 Put on some C.R.A.P. and drive.... |
Designer King
I think it is dye.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
Recreational User
Yeah, dye bleed-through.
Czar of C.R.A.P.
Well I also think it is dye. My wife informed me that it was mold. I think I have enough pieces of the covering to make patterns. Vinyl is on sale right now at Hancock fabrics so I think I will get some and make an attempt at custom covers. The foam is really in pretty good shape. It took me squishing it into a 5 gal bucket and then sqeezing out the water. So I think it will hold up for a while yet.
Designer King
Not an expert by any means, but I was assuming it didn't smell moldy.
you are going to cover them all up right? Why care?
Fat butt 911, 1987 |
N-Gruppe doesn't exist
looks like mold to me, like others said what did it smell like before? of course some molds dont give off any oder.
suprised all the cleaner you used didnt start eating up the foam. if it doesnt stink and the color doesnt bleed thru to the coving...who cares what it looks like. make sure you let it air dry completely before recoveing.
Ted '70 911T 3.0L "SKIPPY" R-Gruppe #477 '73 914 2.0L SOLD bye bye "lil SMOKEY" ![]() "Silence is Golden, but duct tape is SILVER.” other flat fours:'77 VWBus 2.0L & 2002 ImprezaTS 2.5L |
treat it "as mold"..., (yes,..assume) for sure (why not?) ,..then, on to the next steps,....
Best, Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
