whiskyb's Avatar
Rear main Oil Seal
I have a 1977 2.7 that is in need of a new oil seal. Motor is out and on the bench. I always put the seals in till they bottom out in the case. The one in it now is flush with the case. It could go in about another 8mm till it bottomed out.
Which method is correct?
Whiskyb
69 911
Wasaga Beach
Old 04-09-2009, 09:23 AM
flush is how the factory did it, but if the seal has worn a groove in the crank, farther in will let it seal on a fresh surface.
206 637 4071
Old 04-09-2009, 09:30 AM
Almost Banned Once
sc_rufctr's Avatar
8mm seems like a long way...
All Good information. Thanks
- Peter
Old 04-09-2009, 09:35 AM
whiskyb's Avatar
I'll try it as I have always done then and go in a little further than flush. Good thing it comes out easy!
Whiskyb
69 911
Wasaga Beach
Old 04-09-2009, 10:02 AM
jevvy's Avatar
I trust you were joking with that comment?
If not then the new seal might not be seating correctly as it should be a pretty tight fit or you risk having to re-visit it soon
'89 3.2/3.6 coupe
Old 04-10-2009, 12:32 AM
whiskyb's Avatar
I thought about that quote as I typed it. I was referring to the actual motor coming out if their was a problem. Good catch though!
Whiskyb
69 911
Wasaga Beach
Old 04-10-2009, 05:21 AM
