<insert witty title here>
engine won't turn by hand
What's the process for troubleshooting this? The engine is on the floor in the garage, no tranny attached, so it's not a question of the tranny being locked in 2 gears at once.
I'm moving all the bits from my 72 2.4 over to a 67 2.0. The engine will turn CCW (just a little bit) no problem, but won't turn CW at all. It's not a question of compression - I know what that feels like. It's locked. When torquing the flywheel bolts I didn't realize until it was too late that the engine turned CCW maybe 1/2 to 3/4 of a revolution. So it could be slipped chains, but in reading here I read that you should be able to feel and/or hear this, and that wasn't the case. Also, in that case the I should be able to turn it a bit in both directions, but again that's not the case. It'll turn fine CCW. To confirm, I'm using a 19mm wrench on the crank pulley, not the 22 fan pulley. I'll pull off the chain housing covers if necessary, but I'd rather eliminate other variables first. Thanks.
Current: 1987 911 cabrio Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster |
Your cylinder walls are probably dry. Get the engine on its side and add oil through the plug holes, flip it and do the other side..been ther done that.
Bruce |
If that were the case, it wouldn't turn CCW would it?
Czar of C.R.A.P.
Chain.......... Pull the covers and check
66 912 Coupe 84 Carrera Cab Hardtop HC3.4 Hyper Carrera 2005 Dodge Magnum 5.7 HEMI Cabriolet Racing And Performance C.R.A.P. Gruppe #1 Put on some C.R.A.P. and drive.... |
Spark plugs are out, right?
'83SC '76 911S - Sold. |
Chain.....
Caveman Hammer Mechanic
Check your flywheel bolts and pressure plate bolts, sounds like a too long bolt bottomed out.
eric
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 |
Pull the chain covers & check cam timing. If something has come adrift you could have valve/piston interference or the chain hung up on a guide. As stated before, if it moves slightly backwards I doubt the pistons are frozen in the bores. Don't force it until you check.
I backed out the pressure all the pressure plate bolts and the engine turned normally. Then I tightened them one by one until I found the one that was too long and was catching on something inside. I compared it to the next bolt around and the difference was about 2 or 3 mm, tops. I ground it down, reinstalled and now all is good. I'm sure glad I didn't jump the gun and pull the chain covers!
Czar of C.R.A.P.
Why might I ask is the bolt too long. Did you not use the correct bolts for the flywheel. Naughty... naughty....
915 being mated to an engine that originally had a 901. It was a pressure plate bolt, not a flywheel bolt, and yes it was the correct bolt for the 915 - it all came off my 2.4 engine, which was running and shifting fine. The perplexing thing is that it's only 1 bolt out of 9 that was too long. I did replace some of the PP bolts when I replaced the clutch last year, with the correct bolts. I don't remember for sure - I might have only replaced 1 but I thought I replaced a few. Oh well, all's well that ends well.
Author of "101 Projects"
Flywheel bolts are meant to only be used once...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
I think we're maybe getting terminology mixed up here. There are 6 flywheel bolts that require a 12-point socket to attach the flywheel to the engine. They sit in a tight circle near the centre of the flywheel, with a diameter of maybe 4 or 5 cm. I replaced the flywheel bolts.. There are 9 pressure plate bolts that require a hex head socket (6mm? 8mm? can't remember) to attach the pressure plate to the flywheel. They sit in 3 groups of 3 around the circumference of the pressure plate. I re-used the pressure plate bolts.
Hola, glad it was a simple fix. eric
