Can anyone tell me what jetting they have there Weber Carbs on a 3.0. I'm starting my project, and want to start at a good spot on the jetting. I'm looking for main jet setting and air jet setting. Thanks
Try 145 mains ,180 airs, f7 emulsion ,60 idel jets that will get you started.
Cheers Chuck ,also 34mm venturis |
Thanks. Keep them coming...
For 46IDA 3C Weber carbs set up on a 3.0 by PMO, 55 idle jets, 180 air correction jets, 150 mains, F3 emulsion tubes, 36 mm venturiis, 4.5 tall aux venturiis.
Rod |
Thanks hotrod. I'm running 40's with 34 mm venturis. Thats what the formula i was told to use came up with for venturi size. I love these forums.
