Monkey Butt Forespin
84_Carrera's Avatar
3-piece BBS wheel reseal procedure?
About to receive my new-to-me 3-piece BBS RS wheels, and I'm looking to pull them apart & re-seal them.
I've been told to use Dow Corning #832, which I'll be getting in this week.
Does someone have a decent write-up on the process? I'm looking for where / how much to apply a bead of silicone rubber to, etc. Separation seems to be remove as much of the previous sealant & tap vs. pry.
Can I assume blue loctite will be adequate for the bolts / nuts? I read 23 lb-ft for the bolts, and in a crossing pattern for loosening / tightening, 24-48 hours to cure before mounting & inflating.
I'm not looking to do a full off restoration of these wheels, as they look pretty clean, but I'll likely polish the front outers. If I run into issues with the hardware, is there a place I can get them?
Thanks guys.
Fred Hurder Jr
For Tech Questions:
'84 911 Carrera Cabriolet (US)
Weltmeister Chip, Fabspeed Euro Pre-Muffler, M&K 1-in / 1-out Muffler
22 ERP /29 Sander Hollow T-Bars, Bilstein HD Struts / Sport Shocks
ERP Poly-Bronze Bearings (A-Arms & Spring Plates), Stock Swaybars
Turbo Tie Rods, '92 C2 5-Spoke wheels w/ 1" adapters, Drilled Zimmermans
Yes, I drive mine as much as possible. If it's >32° & sunny, I've got the top down.
Old 04-12-2009, 03:20 PM
silver911rdb's Avatar
I made up a set of 17" fuch replica wheels useing BBS rim halves and machined forged centers from 16" fuch donor wheels. When I ordered the parts from BBS they also suggested I use their sealing ring. This sealing ring was a thin spacer that was sandwiched between the rim halves. This spacer had face grooves machined on either side with large rubber o-rings placed within the groove. These o-rings sealed the wheel and no sealant was needed. I'm not sure if they use these rings on their other wheels but I thought I'd mention it just in case they did.
You should be able to get all the hardware you need from BBS motorsports in Florida.
-Rich-
1984 911 Track
1985 911 Track/Autocross
Old 04-12-2009, 04:11 PM
