Wandered off somewhere...
Drdogface's Avatar
Need elec window switch wiring diag...78 SC
Hopefully some one will have what I need or at least a source for it. The guy fixing my door panel apparently unplugged the elec. window switched and, it seems, did not wire them back on correctly as neither window works now. The fuse is OK. This is a 78 SC.
There are five wire sets that plug into five spade connectors. If any one can gimme a clue where these go correctly I'll get my car back soon.
I looked in the Pelican diagrams but didn't see what I needed.
Mark...
Porsche Boxster S
2012 Jeep Wrangler Rubicon..Crush Orange
Old 08-23-2010, 03:33 PM
pete3799's Avatar
Just lent my Bentley to a friend for this very problem.
Sorry i can't help at the moment.
Pete
79 911SC RoW
Old 08-23-2010, 03:51 PM
The interesting thing to know is the numbers on the back of the switch all get different color wires as they are not the same from switch to switch
Bruce
Old 08-23-2010, 03:52 PM
crustychief's Avatar
Power Window Switch schematic
A nose heavy airplane flies poorly, a tail heavy plane flies once.
Old 08-23-2010, 04:13 PM
Drdogface's Avatar
Thanks Chief: You are da' Man....
Mark...
Porsche Boxster S
Old 08-23-2010, 05:33 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Old 08-24-2010, 06:33 AM
cattman's Avatar
I am not a wiring diagram expert, but need to know which wire to connect to which connector for the window switches on my 87 911. Can someone assist me? I had to unplug the switched to remove the door panels, and now am stuck with the windows down, so can't drive in case it rains!
2005 Porsche 911: 997S, supercharged to 530HP
1987 Porsche 911: Concours prep OEM guards red on black
Old 09-14-2010, 02:44 PM
cattman's Avatar
I think I figured it out. If I am correct, it's like this for the Driver's side switch for the passenger window:
1 takes the red and white wire
2 takes the red anc black wire
3 and 5 take the solid red wire
4 takes the brown wire.
I will look at my Bently for the 87 and run with it, and report back!
Old 09-14-2010, 02:50 PM
yep, im slow in the head
carslutt's Avatar
Send a message via Yahoo to carslutt
great info
1978 911sc Targa - CNC plasma/router cut parts, tig welding, sheet metal work, VAG-COM, LM-1. let me know if u need something
Old 09-14-2010, 05:01 PM
cattman's Avatar
Well, no dice. I followed the diagram in Bentley's for the '87, and I can't get the switches to work. All that I've done is:
-unplugged the switches (all 3) to get the door panels back on.
-reconnected the driver's door driver's window switch, and got it to work. Took it out, and reconnected the others. Now none of them work.
Any thoughts?
CATTMAN
Old 09-14-2010, 05:54 PM
pete3799's Avatar
Checked your fuses?
Pete
79 911SC RoW
Old 09-14-2010, 06:27 PM
