Sneakin' 'Bout
Spark/Ignition testing
Hi, I have a 71 911E and it wont start. It's getting plenty of fuel, i can smell it in the engine compartment. I had the MFI rebuilt last year and they also put in a perma tune ignition. I don't believe the car is getting any spark, but Im not sure how to test for that. Where should I hook up my volt meter and test for spark?
1971 911E Canary Yellow w/Mahle wheels and AC
Old 06-15-2009, 10:47 PM
T77911S's Avatar
pull a plug wire, connect an old but good sparkplug to the wire and lay it on the engine. get someone to turn it over and look for spark. DO NOT hold it
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 06-16-2009, 03:50 AM
smokintr6's Avatar
Send a message via AIM to smokintr6
^^+1 ...or use a timing light.
Old 06-16-2009, 05:49 AM
Sneakin' 'Bout
Like I mentioned, I can smell gas in the engine compartment after I crank the engine, is this really such a good idea? I think buying a timing light is a better idea.
Old 06-16-2009, 07:32 AM
muck-raker
kidrock's Avatar
the smell of gas is not necessarily a good indicator that your engine is getting fuel. On a carbureted engine, I would pull the main fuel hose to either A) the fuel filter, or B) the carburetor itself, to ensure that fuel is making it towards the combustion chamber.
This does not mean that your vehicle is not suffering a spark issue. +2 on the timing light...they are inexpensive and are a good multipurpose tool.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 06-16-2009, 09:49 AM
Sneakin' 'Bout
Remember, this is a fuel injected engine. Is there a way to hook up a volt meter on the cap/rotor to see if 12volts is getting through?
Old 06-16-2009, 12:14 PM
304065's Avatar
Do NOT hook up any meter to the coil or permatune box.
Follow the troubleshooting instructions on the permatune web site.
If you put a meter on the coil you will blow the box.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 06-16-2009, 12:50 PM
