Axle Orientation
I tried a search, but could not find the answer I'm looking for.
When replacing CV joints (or whatever might cause one to remove the axle) does it matter which end goes in/out? There is a splotch of paint on my axles and I'm wondering if that is a mark for orientation. I know there's an orientation for the CVs themselves, but not sure about the axle. Thanks!
1979 911 SC Silver 2002 996 race car 2005 Ford Excursion |
If the CV's are identical on each end, I don't think it makes any diff which way you put them. Torsion bars, while they look similar, are another deal altogether.
I've swapped axles around on a 944 in the past. As long as the axle type is the kind with the same CV configuration on both ends, it's fine.
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
Somatic Negative Optimist
The axle shaft experiences torque for many years in the same direction and I would keep that same rotation by marking the axles before removing. Unlike Carrera, SC-CV's can be switched on the shafts (maintaining the same rotation) to get a new running-surface in the races for the balls. That's what I did when checking the CV's couple years ago.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Thanks everyone for replying.
I agree with Gunter. I was told you can switch them from side to side, but reverse the inside to the outside so the axle itself is still "twisting" in the same direction. I hope that makes sense. You can reverse the CV joints too to change the "wear side". it's Friday and this probably doesn't make any sense.
Robert Williams 70' 911T |
