Quick Question Pertronix/Points (Ive searched
Hey Guys ~
Currently in the process of changing points to the Pertronix. I removed the points & wire connector from the distro housing. Then ran the Pertronix black & red wires through hole in the distro housing, these wires then hook up to the coil. Here is the question: What do I do with the wire the that was connected to the points outside of the distro housing? Tape it up?? Pleas help the sun is out... Thanks. |
Thanks for the link - it still does not answer my question.
Dam! Anyone else? Thanks. |
If I'm correct, the wire of which you speak is for your Tach... Also, It may require that you contact Petronix for the answer as I remember when I had a 2.4 engine in my car, I had to call Petronix for the correct wiring diagram. Their number is (909) 599-5955 (They're located in San Dimas, CA) and probably not open until Monday.
What did you determine?
Hey John.......did you get the Pertronix working or go back to points?
| All times are GMT -8. The time now is 04:37 AM. |
