87 carrera - original shocks - how to tell?
I have an 87 carrera coupe
I bought it about 6 years ago with 26k miles and I believe it to be stock.
I didn't get the full service history, how would I know if it was on the orginal shocks? are the a special color or have markings of some sort?
Old 04-18-2009, 07:58 PM
Gordo2's Avatar
From What I Understand
I'm not too familiar with the '87; on my '83 the original rears were black Boge shocks.
No way to tell on the fronts without disassembly - my car has Boge struts (black). When I replaced the shocks (inside of the strut assembly - you can't see them without taking it apart), the strut was full of oil - from the factory. I believe they were originals (~20+ years and 150k miles and still going strong).
I replaced my fronts and rears, expecting a significant difference in ride. Oddly enough, it wasn't that noticeable. Either way, as old as they were, they were due to be replaced.
Good luck, Gordo
Don "Gordo" Gordon
'83 911SC Targa
Old 04-18-2009, 08:22 PM
Good luck, Gordo
Gordo,
I understand that you replaced the front inserts with new Boge inserts, do you have to put some kind of oil in it again or simply insert them?
Tx
Champaign and Burgundy 3.2 (1986)
Ex-C4 91
Ex C4 93
A8 3.0 TDI
X5
Old 04-19-2009, 03:58 AM
Gordo2's Avatar
Boge Struts - Bilstein Inserts
Actually,
I went with Blistein inserts (make sure you buy the correct insert for your strut - Bilstein struts or Boge struts take different inserts).
Gordo
Don "Gordo" Gordon
'83 911SC Targa
Old 04-19-2009, 09:23 AM
Make Bruins Great Again
Por_sha911's Avatar
The originals were not sealed and had to have the fluid. The replacements will be sealed units. So people put oil or antifreeze in there for cooling purposes but many do not.
Joe
Old 04-19-2009, 01:13 PM
Actually,
Gordo
Tx guys
Ex-C4 91
Ex C4 93
A8 3.0 TDI
X5
Old 04-19-2009, 01:24 PM
old man neri's Avatar
The way I knew mine needed to be replaced was when I unscrewed the the top strut bolt and was able to compress the strut with two fingers. It then stayed compressed, I had to pull it up. Ya, that's how I knew they were original and needed to be replaced.
Old 04-19-2009, 01:27 PM
