-   -   replacing electrical portion of ingnition switch carrera?? (http://forums.pelicanparts.com/porsche-911-technical-forum/470053-replacing-electrical-portion-ingnition-switch-carrera.html)
captainlewis 04-20-2009 03:51 PM
Can you replace the electrical portion of the ignition switch without having to remove the steering lock key switch etc,// Thank s JL
sc_rufctr 04-20-2009 04:45 PM
Yes you can but it's not the easiest way to do it... You have to be able to get to the small screws which holds everything together. But why not take the whole thing out?
Our host sells the shear bolts and at $5.75 each (x2) + $62.75 for the switch.
When I did mine I didn't use the OEM shear bolts. Instead I used 12 point bolts left over from another project.
I figured if the crook has a 12 point socket with him he would also have a punch and small hammer in his tool bag.
Formerly Steve Wilkinson 04-20-2009 04:52 PM
I did it recently from under the dash, on an '82--same ignition switch, as far as I know--and with a little ingenuity and maybe some modifying of a small screwdriver it's easier and cheaper than taking the whole unit out, as long as you're agile enough to corkscrew yourself into the footwell head-first.
dshepp806 04-20-2009 05:14 PM
corkscrew is right!!!!
Doyle
1978911sc 04-20-2009 05:36 PM
My back still hurts from that particular corkscrew!!
sc_rufctr 04-20-2009 10:39 PM
E Mail from "captainlewis" replied to...
