-   -   Is there a shorter spark plug tool? (http://forums.pelicanparts.com/porsche-911-technical-forum/470351-there-shorter-spark-plug-tool.html)
john baldwin 04-22-2009 06:09 AM
After reading all the posts on sparkplug removal methods, I ordered the wrench from the toolkit (no toolkit with the car) from a reputable salvage yard. However, despite many attempts, it's just too long for me to maneuver. I resorted to articulated sockets, locking extensions, and hoses (Pelican posts are extremely helpful!). Took a while, but once I got the "feel", what started as a chore became fun.
However, now I've got this wonderful tool that I can't use....see pictures...were they all this long? It's missing the knurled tip that others spoke of in previous posts....could it be aftermarket (says "Klein", which I thought was factory...) Or is it just me....curious. Watch for it in the for sale forum....
http://forums.pelicanparts.com/uploa...1240405575.jpg
http://forums.pelicanparts.com/uploa...1240405629.jpg
http://forums.pelicanparts.com/uploa...1240405655.jpg
sc_rufctr 04-22-2009 06:35 AM
There is a shorter version of that tool. It's less than half the length of yours but otherwise very similar.
911K 04-22-2009 06:43 AM
That tool looks like the one for a 912 maybe? Definitely way too long for a 911. Contact the salvage yard and see if they'll exchange it for the correct tool.
Bill Verburg 04-22-2009 06:53 AM
This one from the tool kit that came w/ my '72 was the best I ever used
http://forums.pelicanparts.com/uploa...1240408427.jpg
Rot 911 04-22-2009 06:55 AM
That sure isn't a 911 tool, more like a 944?
Tom '74 911 04-22-2009 07:28 AM
Mine looks just like Bill V's. It is a great tool to have. Even at it's shorter length, there was a plug or two that took some maneuvering to extract while attached to the tool - there's no way you could get to any of the plugs with the tool in you photo!
Tom
timc 04-22-2009 07:46 AM
This is the tool that came with the later 911's, I know at least 77 and newer. The shaft flex's to make it easy to remove/install in the tight area's of the 911.
The "fixed" shaft tool of Bill V's came with the early cars.
I have no idea where the tool you got came from, but it was not a 911. Possibly, as stated above, a 356 or 912...
http://forums.pelicanparts.com/uploa...1240411482.jpg
Paulporsche 04-22-2009 08:16 AM
Looks like a 944 tool.
Fast Corners 04-22-2009 08:17 AM
John,
Yours is definitely one from a 944. The "flexible" 911 tool (as shown in timc's) post works well for the later cars (84-) & turbos but the earlier "fixed" is the best one I have ever used on the earlier cars. The fixed one really gives you a lot of feel which really helps when it comes to avoiding cross threading the plugs.
john baldwin 04-22-2009 08:23 AM
Thank you all for your help!...now back to the salvage yard..wish me luck!
David E. Clark 04-22-2009 09:52 AM
This one is definitely the best. I only wish that they had designed it to attach directly to a 3/8 ratchet instead of using a 10mm hex.
timc 04-22-2009 10:06 AM
Depends on the car...
john walker's workshop 04-22-2009 10:08 AM
not that hard to weld a 3/8 end on one. 5 5/8" is the magic length. been using this one for many years.
http://forums.pelicanparts.com/uploa...1240420100.jpg
911pcars 04-22-2009 11:45 AM
I agree. However, mine needs a new rubber sleeve that holds the spark plug in place. I didn't see it in the Pelican parts store. I assume the dealer can still get this? Any rubber sleeve replacement options outside of this?
Sherwood
RoninLB 04-22-2009 02:54 PM
Hazet
http://forums.pelicanparts.com/uploa...1240437280.jpg
john baldwin 05-31-2009 05:47 AM
Recognition of two suppliers...
Contacted the salvage yard that originally supplied me the wrong tool (top of photo). Sent pictures from the responses I received on Pelican...this forum is TERRIFIC. After much searching, they located the correct sized tool (bottom of photo). No charge replacement; this after a year of my first receiving tool. dc Automotive...very responsive and honorable! Thank you to all.
http://forums.pelicanparts.com/uploa...1243773800.jpg
