Yellowb1rd's Avatar
Linea Corse Rota fox wheels...
Hi all!
I'm interested in these wheels on Pelican's site:
http://www.pelicanparts.com/cgi-bin/smart/more_info.cgi?pn=LC-FOX-POL&catalog_description=Linea%20Corse%20%28Rota%29%20F ox%20%31%20%28Polished%29%20Wheel%20Set%2C%20inclu des%3A%20%28%32%29%20Front%20%2D%20%31%37x%37%2E%3 5in%20%28%2B%33%35mm%20offset%29%2C%20%28%32%29%20 Rear%20%2D%20%31%37x%39in%20%28%2B%31%36mm%20offse t%29%2C%20bolt%20pattern%20%2D%20%35x%31%33%30
Can someone please tell the exact weight of these wheels? I can't find any info at all in regards to weight. I want a larger diameter rim, but dont want to add a lot of rotational mass.
Old 04-25-2009, 11:39 AM
Monkey Butt Forespin
84_Carrera's Avatar
Shipping weight is 90 lbs for the set, per the page you linked to.
At a guess, that's about... 20-21 lb / 9" & 18-19.5 lb / 7.5", plus your packing.
Sorry, couldn't resist.
Fred Hurder Jr
For Tech Questions:
'84 911 Carrera Cabriolet (US)
Weltmeister Chip, Fabspeed Euro Pre-Muffler, M&K 1-in / 1-out Muffler
22 ERP /29 Sander Hollow T-Bars, Bilstein HD Struts / Sport Shocks
ERP Poly-Bronze Bearings (A-Arms & Spring Plates), Stock Swaybars
Turbo Tie Rods, '92 C2 5-Spoke wheels w/ 1" adapters, Drilled Zimmermans
Yes, I drive mine as much as possible. If it's >32° & sunny, I've got the top down.
Old 04-25-2009, 01:24 PM
3.4 Bigger is better
88-diamondblue's Avatar
Here are the weights
Michael
88 911 Diamond Blue CE Carrera 3.4 HC3.4 member
2020 Honda Passport
Old 04-25-2009, 09:40 PM
Yellowb1rd's Avatar
Wow. That's fantastic! Thanks 88-diamondblue!!!
Hi Carerra84. I noticed the shipping weight too, and I figured the weights pressty close to yours, but I wasn't sure how accurate that shipping weight was. Looks like from the info provided by 88-diamondblue, you were pretty close. Thanks guys!
Old 04-26-2009, 11:54 AM
low944's Avatar
Send a message via AIM to low944
What do factory fuchs weigh??
JW
1983 911 SC
1990 944 S2 (sold)
Old 04-28-2009, 10:49 AM
MBruns for President
JeremyD's Avatar
http://members.rennlist.org/911pcars/WheelWts.html
depends on the size
Old 04-28-2009, 11:05 AM
