GA Emissions/ Cat Bypass/ SW Chip Question
I'm due for my annual emission test in June, the first since installing an M&K cat bypass and SW Chip. I will be re-installing the cat for the test. Question is: Will I be OK testing with the SW Chip or should I swap back to OEM chip?
My SW chip passes in Texas. I do put the cat back. Done this for several years. Ken
That was the answer I was looking for. Do you re-use your exhaust gaskets?
Thanks! |
Yes, for better or worse. No problems though. I even use old ugly HW so it looks unmolested.
| All times are GMT -8. The time now is 09:25 AM. |
