Oil leak from left camshaft pressure line
Noticed the oil leak on the left side. Cleaned it up/started the engine/no noticeable leak. Drive down the road and back. Oil on the left side and a small collection directly under the "T" pressure line fitting.
I'm going to do double check to be sure(I like the baby powder idea). It seems from what I've read that it's not uncommon for these to leak over time. My plan is to do a full replacement on the lines/fittings. Anything that I need/should be aware of or should replace when I do this. It looks pretty straightforward in the Bentley manual? THANKS
PCA National Instructor 93 RS America (some things done to it....)(gone) 85 Carrera (gone) 06 BMW M5 (gone) "If you ain't first, your last" |
