how to adjust the CO
how to adjust the CO and were is located
thank to advance
Old 04-27-2009, 06:38 PM
sudo apt-get purge 930
equality72521's Avatar
ummm, a little more info about your car???
--clutch-monkey
Old 04-27-2009, 06:41 PM
is a 911 t 1974
Old 04-27-2009, 06:57 PM
Black and Blue
Kemo's Avatar
Send a message via Yahoo to Kemo
if you have CIS you might be better off having a pro do it...
In order to really adjust the CO, you need to have the right sensor equipment...kinda pricey. I think the going rate just to get a device to measure the gases right is about 300bucks. something like an LM-1.
Some have had good results from the "lift the plate" method with the CIS. The adjustment access hole is just to the left of the fuel distributor. basically, you slip a 3mm hex wrench down in there to adjust. If you havent done it before, its almost too hard to put into words.
do you have carbs or CIS?
Kemo
1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore
1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver
Old 04-27-2009, 07:31 PM
Black and Blue
Kemo's Avatar
im a bit confused too...1974 was the 911S
so CIS? do you have a pic of your engine to post?
Kemo
Old 04-27-2009, 07:42 PM
i have CIS
may cars model is 911 targa 1974
sorry for all the cuestions sinc i live in acapulco mexico there are no qualified profesionals
thanks
Old 04-28-2009, 06:02 AM
