-   -   HELP: MFI engine starts but no idle (http://forums.pelicanparts.com/porsche-911-technical-forum/471528-help-mfi-engine-starts-but-no-idle.html)
356RS 05-19-2009 09:46 AM
Yes Francois, you might want to make sure the throttle lever is at rest on the stop. Maybe you could remove the linkage to make sure. MFI is great but there are so many factors that must be right on to make it run good. I need a big check-off list when doing a CMA to make sure I don't forget something. Lots of work, but a great ride when it right.
