rs6er's Avatar
Send a message via AIM to rs6er Send a message via Skype™ to rs6er
Mirror Repair Repair
So I searched the forum because my driver side flag mirror was loose. I followed an excellent how-to and took everything apart. I only had one problem. One of the 3 clips that attaches the glass from the frame came loose (It didn't break.) I epoxied it back to the glass before reassembling. Unfortunately it didn't line up correctly. Now I can only get two of the clips on the back of the glass into the frame.
Is there a way for me to dissolve the epoxy so I can make it right? Obviously, I can't use any heat or the glass will break.
John
Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance.
Old 04-28-2009, 01:09 PM
rs6er's Avatar
Bump for answer
John
Old 04-28-2009, 05:20 PM
I'll give it a stab. Try cutting it out with a razor knife, scrap and cut until you have removed enough to start wiggling it loose. Good luck.
O2 In Sully We Believe
Old 04-28-2009, 06:08 PM
Zeke's Avatar
Glass takes a lot of heat. What it doesn't like is sudden temp changes. Go slow.
Old 04-28-2009, 06:13 PM
