<insert witty title here>
Christien's Avatar
Fuel return line banjo fitting crush washers or o-ring?
Wow, that's a mouthful. I couldn't anything in Pelican's parts catalogue and need some asap. When I pulled it off I lost one. The remaining one looks like some kind of fibrous material, I can't tell what. If it weren't for a fuel line I might think it was cardboard or something, but of course it's not that. I tried some copper crush washers, but I'm getting a very slow leak (maybe 1 drop per minute). Now, it might be because I couldn't find the right ID size so had to dremel it out a bit, then lightly ground the surfaces smooth, so maybe I'm not getting a good seal because of my less-than-perfect work. But the gasket that was on there before was definitely not copper.
BTW, this if for a carbureted fuel setup, not MFI. Return line is blocked off.
Any help?
Thanks!
Current: 1987 911 cabrio
Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster
Old 05-02-2009, 11:41 AM
Those use a fiber gasket, not an O-ring. Its a 901.100.915.00.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 05-02-2009, 11:56 AM
Christien's Avatar
Thanks so much! FWIW, I did try the parts diagram lookup, but it looks like porsche.com changed the location of them, so the link from Pelican doesn't work anymore.
However, that part #'s "more info" link did bring up a diagram, and it's the banjo fitting at the carburetor. I need the one for the return line at the fuel tank, above the suspension pan. They look to be the same size - do you know if they're the same gasket?
Old 05-02-2009, 12:22 PM
