-   -   Need help with CIS airbox measurement please (http://forums.pelicanparts.com/porsche-911-technical-forum/472248-need-help-cis-airbox-measurement-please.html)
Won 05-02-2009 11:39 AM
If anyone has a CIS airbox sitting on their bench, could you please measure the diameter of the opening on the box under the throttle body, as well as the bolt spacing for the throttle body?
I need measurements A and B:
http://forums.pelicanparts.com/uploa...1241289578.gif
Thanks! SmileWavy
boyt911sc 05-02-2009 02:16 PM
Dimensions for A & B.........
Thanks! SmileWavy
Won,
A = 70 mm
B = 65.5 mm
Measurements taken multiple times and these were my ave. readings. HTH.
Tony
Won 05-05-2009 12:38 AM
Thanks Tony! That's just want I wanted.
For future reference, those are the same dimensions as the 3.2L throttle body. If I went with 3.2L intake on my engine and megasquirt but kept stock ignition, I would have lost the vacuum advance which is . I wanted to know if I could use the SC throttle body with a vacuum port above the butterfly. According to Tony's measurements, SC throttle body will physically fit the 3.2 intake.
Then there is always the EDIS route.. ;)
