Bird. It's the word...
Fishcop's Avatar
Can a Ring and Pinion Set be Refurbished?
Hi Guys
I picked up an old mag cased 915 (4spd) a while ago to grab a few bits and pieces I needed. Unfortunately one of the bits I hoped to use turned out to be kaput - the 7:31 ring and pinion Not to matter, I went with good the 8:31 I had.
Some pics of bad R&P...
Anyway, rather than make an interesting paper weight of these items, I was wondering if anyone refurbishes these items with any success and within a reasonable price range?
I note I can pick up a secondhand 7:31 R&P for around $750-800 so refurb would have to be a bit cheaper to be worthwhile...
Any thoughts or experiences?
Cheers
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 05-02-2009, 09:48 PM
John,
Sorry sir,..those are now "ornamental objects".
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 05-03-2009, 12:29 AM
Fishcop's Avatar
Thanks Steve... I figured that was the case
Cheers
John Forcier
Old 05-03-2009, 02:12 AM
grateful user
don gilbert's Avatar
rp
or trot line weights
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do.
Old 05-03-2009, 07:00 AM
