A/C Condenser fan
I recently had the Air Conditioning on my 86' Carrera checked and charged and the shop told me that if I put a fan on the condenser I would get much better cooling. Is this true and if so what size fan should I use. Any information would be appreciated. Small dual fans etc. Thanks, Bruce
Old 05-17-2009, 06:42 PM
Make Bruins Great Again
Por_sha911's Avatar
There has been much posted over the last few years about spal fans on the rear condensor. Do a search and I'm sure you'll find plenty of info.
Joe
Old 05-17-2009, 07:55 PM
Thanks. I'll check.
Old 05-17-2009, 08:16 PM
Mitch Leland's Avatar
Condenser fan...
Like Joe says, there's a ton of information that has been posted regarding the addition of adding fans to the rear condenser. I believe most people agree that they do help in stop and go traffic, but once under way they don't make a big difference. Certainly they are added weight where you don't want it.
I considered them, here's some information that I got out of the Summit catalog a year or so ago. I was going to use 2 of these. You need to balance CFM's against amps.
Mitch Leland
"03" 996 C2S-LS3 V8-480 HP
"84" 911 Turbo Look-Sold w/ found memories
Old 05-17-2009, 09:21 PM
jhubs's Avatar
Here is a thread that may help: How's your A/C holding up this summer?
1995 993 Carrera, Guards Red Coupe (current)
1987 911 Carrera, Marine Blau Metallic (06-08) Gone but...
1965 Yellow Mustang Convertible (65-05)
__________________________________________
It is always a good idea to keep the pointy end going forward as much as possible.
Old 05-17-2009, 11:50 PM
The condenser fan makes a huge difference. My A/C system has worked well for 6 years. (And if you think that the weight of the fan will affect your car....well let's just leave it at that)
Here's what I said in a post in 2003 when I did my system;
I've studied the system because I'm going to get the a/c working in my 78SC this summer. I think the big (but totally unnoticed) problem with 911 a/c systems is the lack of air flow through the condenser; particularly at idle. We all look at that engine fan and think it pushes a lot of air but it doesn't. At 6000 rpm the fan pumps about 3000 cfm and the engine draws about 300 cfm. At idle (1000 rpm) that's 550 cfm. That's an air flow of 4 mph through the trunk lid opening at idle. Not enough!
Get a 9" pusher electric engine cooling fan (J.C. Whitney) and mount it on the left side of the condenser. Check very carefully so you have enough room. This fan blows at 660 cfm and since what goes out has to come in, at idle you'll get 2X660 plus 550 = 1,870 cfm. That's about 13 mph air speed through the condenser. That should make a big difference in your a/c performance.
Old 05-18-2009, 07:47 AM
jhubs's Avatar
He is 100% correct. I found that even the one 7" spal fan I installed made a big difference in the at-vent-temp in the cabin. Replacing the A/C hoses with US brand hoses (NOT OEM hoses), installing the passenger side floorboard air extension and installing the one puller fan changed the at-vent-temp from mid 40 degrees F to 39 degrees F. All for about $500 because I did not install the hoses or the fan myself..
Jerry
Old 05-18-2009, 10:38 AM
Thanks for the confirmation Jerry.
Old 05-18-2009, 03:27 PM
Mitch- Thanks for the web site information.
Old 05-18-2009, 03:31 PM
