- Jesse |
Get ahold of Chris Kirby.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s Addicted since 1975 |
What can cause this?
What is actually damaged?
Should I be looking for another engine or can this be repaired? ![]() ![]()
Zorin '79 911 SC Targa, 3.2L Carrera engine - Zenith Carbs - 36mm vents, Lightweight Flywheel and PP '00 BMW 540i - Sports Package (The Beast) '99 LandRover Disco |
Ouch, you're looking at a new engine case at least.
1979 911SC "Frankencab" Dave |
FFFFFFFFFFFFFFFFFFFuuuuuuuuu
Oh no. Well yes, a case and, at the very least, a rod I suppose. It's more likely that quite a few parts have been damaged in the mess that caused that. I can't believe it was still running.
1989 Carrera 3.2L in 993 bodywork |
Holy
Even if that could be repaired, I doubt I would trust it. It would be interesting to see how fragged the internals are because thats a serious crack. Put another way, I'm morbidly curious... pics please. If I were you I'd start looking at finding a donor engine... perhaps moving some of your upgrades to the new engine and selling whatever else is good as parts. Tough break. Good luck with the repair/replacement.
Don't Lift... Don't Lift... Don't Lift ![]() ![]() ![]() '75 Targa in "Arrest Me" Red, 3.0SC ('79) engine, Bilsteins, Turbo Tie-rods, SSIs into 2-1 M&K muffler... and looking for my next upgrade. |
I wonder is something from the road hit it. That seems like a strange place for a broken rod to hit.
Wow. Never seen anything like that. So sorry. It makes my stomach turn.
Love to know how that happened. Were the engine temps ok when it failed?
82 911SC Coupe Chiffon / Chocolate 9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD) |
Good news... it's apparent that starting up the oil starved engine the second time around didn't do any additional damage.
Sorry... I don't mean to be a jerk in your bad situation. I just couldn't resist being my normal smart a$$ self. That's a bummer deal. However there have been several 3.0s in the FS section lately that appear to have been great deals. Good luck! |
Warren Hall Student
That's just bad luck. You must have run over something that bounced up and hit the case.
The engine probably stalled when crankcase ventilation was interrupted which is a good thing otherwise you would have destroyed all the internal parts if you had dumped oil and kept driving. As long as you didn't drive without oil you'll be able to save the engine. This area where the case broke can probably be welded. At any rate the motor should be pulled and the oil return tube removed. It's possible you can have this fixed without breaking down the motor. After welding is complete you can replace the oil return tube with a collapsible one. Before welding you should get a small grinding tip and lay a valley for the weld bead. The repair will either work or it will leak oil but it's worth a try in my opinion. If it doesn't work and leaks oil then look for another case and monitor your oil level closely until you find a replacement.
Bobby _____In memoriam_____ Warren Hall 1950 - 2008 _____"Early_S_Man"_____ Last edited by Bobboloo; 05-06-2009 at 10:03 AM.. |
Sleep Deprived and Grumpy
Just a note if you can prove that an object hit the engine case while driving and you have full coverage you might get through this very unscathed!!
I had a friend with a similar issue, he was driving and a piece of rebar went under the car and bounced up into the engine case . He had full coverage and the insurance carrier covered all the cost of a new case engine rebuild and on and on. Make sure you confirm external damage on the road with a mechanic. THen your good to go!! Jon W. |
UnRegistered User
Pull your sump plate and have a look inside....
Bill K. "I started out with nothin and I still got most of it left...." 83 911 SC Guards Red (now gone) And I sold a bunch of parts I hadn't installed yet. |
Hilbilly Deluxe
I would think that if something hit the case hard enough to do that, you would know it because it would move the whole car. My guess is that damaged came from a rod end, from the inside.
I hate to say it, but I bet at the very minimum you need a new case, probably new rods, probably new P & Cs. If I am right, your best bet would be to source a new engine, and sell off any parts you have that are still good, heads, cam towers, chain boxes, and if you are lucky, the crank. Sorry man, Tom |
In the last photo, you can see that something came up and whacked the tube very hard, causing it to dent and break apart.
1985 Carrera Targa in the fastest color......Black........Growing list of goodies now includes SW Chip, M&K premuffler, Sport muffler, DME update, etc. |
Habitual User
It appears there may be fractures (cracks) where the adjacent tube enters the case.
![]() Don
![]() '80 911 Targa |
![]() Hard to tell without seeing it in person, but a couple of these highlighted areas look like scuff marks or gouges.
UNDER CONSTRUCTION!
after a close look i cant see how this happened from the out side.the damage apears to be on the back side of the oil tube. how did the oil tube syrvive a impact like that? and where you driving backwards?.
im thinking the inside out. i think theres a better chance that a rocker shaft or somthing slid down the return tube and and wedged it self into the rotation of the crank rod. but no matter what did it you will find out when you tear down. sorry to here about this, but there is a bunch of knowledge on this forum and you will get back on the road with out a doubt. cheers ed
Sometimes the first thing that comes to mind should be the last thing that you do!
Looking at the position of the sump drain plug, I'd guess the marks are on the front side of the tube which would be consistant with something hitting it at speed. Further, a closer inspection of the broken fragment may reveal a point of impact where the alloy actually bulges a bit from the hit--could possibly be seen with a magnifying glass. All speculation, but worth a try as the alternative is very ugly.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip |
If you hit something your auto insurance should cover damage if you have full coverage. Before you do anything call your insurance agent.
82 911SC 74 MGB 97 Land Rover Discovery |
If it is not covered as dammage under insurance I like the idea of welding in place.
I would still dump the oil and strain it, cut open the oil filter, remove the spark plugs and see if the motor turns ok by hand, check valve clearances and operation, and maybe do a leak down. If all is good, removing the oil return tube and having the pice welded in might just work. Beats $5k plus for another motor of questionable condition. Quote:
